06-19-2013 03:05 AM
I'm studying for the CLAD and one of the lines in NI's preparation document here is this:
What is the interaction between calling VIs and subVIs using VI Server?
I know how to use the "Call By Reference" function to call a VI, but not necessarily a subVI. I thought a subVI is always loaded with the calling VI and has nothing to do with VI Server. What am I missing?
Solved! Go to Solution.
06-20-2013
02:56 PM
- last edited on
11-19-2025
11:08 AM
by
Content Cleaner
Hi Bmihura,
I think this article will clear up how the VI Server works with subVIs called dynamically or statically.
Best Regards,
06-20-2013 03:03 PM
Yes, that makes sense; I interpreted the question wrong, as in "calling this or that" instead of "calling VIs" and "subVIs". Thanks for the link.
