What is the mathematical function associated to linear, map ranges, polynomial, table scale?
What is the mathematical function associated to linear, map ranges, polynomial, table scale? I'd like to use the scale of daqmx for use with other types of data.
(3,114 Views)
Have you checked the context help. I haven't looked lately, but the is the sort of thing it usually take includes.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,052 Views)
yes, refer to the help, but only found information on the first option "linear". what I intend to is to be able to climb a number, using one of the existing scales, but don't be that mathematical function is necessary to use.
(2,947 Views)
