What is the maximum array dimension you have ever used?
LabVIEW has the somewhat bizarre ability to create and manipulate arrays of any dimension. I've never used more than three, and find it difficult to wrap my brain around how one could effectively organize information into higher-dimensional arrays. Just curious to learn what others have done with this ability
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 1 of 10
(4,906 Views)
I had one situation where I needed to created a 4 dimension array to hold coefficients for a correction equation for a toothed wheel.
channel, tooth, axial position, equation coefficients.  2 x 120 x 7 x 5
Message 2 of 10
(4,897 Views)
We'll, I don't like arbitrary limitations, so it is a good thing that it does not stop at three dimensions. Of course, the more dimensions you have, some of them need to be smallish so you don't run out of ram. (Especially since arrays are contiguous in memory).
There is some use for higher dimensions, e.g. if you have a couple of 3D arrays of equal size, you might consider a 4D array instead.
Message 3 of 10
(4,894 Views)
I've been doing a bit of a mental exercise just for kicks...
With a 2D array, usually the 1st dimension is called the "Row" and the second one is called the "Column".  When you add the 3rd, that index is called the "Page".  These are all pretty common.
Assuming the metaphor in use is one of numbers in a 2D grid on paper pages, how would one extend the metaphor?
What do you get with multiple pages? A book!
4th dimension name: Book
What do you get with multiple books? A bookshelf!
5th dimension name: Bookshelf
What do you get with multiple bookshelves? A library!
6th dimension name: Library
What do you get with multiple libraries? A campus!
7th dimension name: Campus
What do you get with multiple campuses? A university system!
8th dimension name: University
Now I'm not sure where to go...
Message 4 of 10
(4,853 Views)
Actually, the first dimension is column, the 2nd dimension is row.
If you wire an X dimension array to the index array function, you can read the order from bottom to top if you hover the index inputs to get the official LabVIEW names.
Column
Row
Page
Volume
Dim 5
Dim 6
But your extensions to shelf, library, campus, ....  all make sense to me.
Capture
Message 5 of 10
(4,848 Views)
Post-Doc?
_____________
Message 6 of 10
(4,840 Views)
Column
Row
Page
Volume
Dim 5
Dim 6
You  could fill in bookcase and aisle between shelf and library.
Message 7 of 10
(4,829 Views)
Just a few thought starters. I think we can expand a bit, but my data structure is out to the 37d - zero indexed obviously. I’m not “married” to the positions...
Example: (typical CERN water cooler chat)
Mike: how’s that Kudosky Array working for ya Jim?!
Jim: Getting a bit cumbersome to manage...any suggestions?
Mike: Easy, convert to byref, abstract to the Laplace, rinse repeat...
Jim: Array! Thanks for the help!
0 Newtonian Array / Element
1 row
2 column
3 page
4 book
5 canon
6 compendium
7 library
8 Academy
9 council
10 association
11 nation
12 continent
13 hemisphere
14 planet
15 copernican
16 galaxy
17 alliance
18 federation
19 empire
20 universe
21 Space
22 Tab
23 HAL
24 42
25 multiverse
26 OO
27 Delacor
28 Wirebird
29 Powell
30 Kudosky
31 Hawking
32 Laplace
33 Feynman
34 Leibniz
35 Gauss
36 Euler
avoided: cluster, axis, union, super, as they obviously would be confusing terms when relating to traditional code definitions.
Message 8 of 10
(4,793 Views)
I think 'Chapter" should come between 'Page' and 'Book'
Message 9 of 10
(4,747 Views)
