Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
What is the minimum analog voltage that can be read using a PCI 6024 E card?
Himanshu
Member
02-03-2002
11:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
PCI 6024 E Card, no signal conditioning ,LabVIEW 6i
0
Kudos
Message
1
of 3
(2,610 Views)
Reply
Re: What is the minimum analog voltage that can be read using a PCI 6024 E card?
markwysong
Active Participant
02-04-2002
08:57 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
For a PCI-6024, it is a 12-bit board with a maximum gain of 100. Therefore, the board can be set for a range of +/- 50 mV, with a resolution of 24.2 uV.
Mark
0
Kudos
Message
2
of 3
(2,609 Views)
Reply
Vishal
Member
09-15-2003
09:46 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Can u please give vis for gain settings for PCMCIA E series card.
0
Kudos
Message
3
of 3
(2,609 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
