What is the most memory efficient way of waiting a certain amount of time?
Between my Senior Test Engineer and I we use way too many methods of waiting a predetermined amount of time. Is there a "best" (with regard to memory efficiency) way to wait a predetermined amount of time?
Message 1 of 9
(3,636 Views)
I have to ask: What's wrong with the Wait function?
Message 2 of 9
(3,632 Views)
I also think about 'memory efficient'. I can't imagine a way to wait that takes more than a few bytes.
Felix
Message 3 of 9
(3,627 Views)
Short of inhibiting the CPU clock the Wait function is the best method of waiting.
Bracing for a re-wording of the Q,
Ben
Message 4 of 9
(3,624 Views)
Ben
Depending on how long you need to wait and whether or not you have the requirement to abort the wait early a queue or notifier with a timeout is also a good way of waiting. This gives you the ability to abort early if necessary. This is handy if you have long wait times.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 9
(3,607 Views)
I never really thought about using a queue in that way before.  You have a dequeue element with a timeout.  When it times out, your time is up.  If you want to stop the timer early, then you place an element in the queue from anywhere else in the code. You don't even care about the data in it and wouldn't have to wire it up at all.  You have an output that tells you whether it timed out or not and can be used as a decision on whether to continue with the code normally or to stop the loop.
I like it.  I'll have to keep it in mind for the future.
Now if you have a situation where you don't want your loop to hold waiting for the time, but perhaps doing certain things when the time is not up and something else when the time is up, then the elapsed time Express VI works well for that.
Message 6 of 9
(3,593 Views)
"Depending on how long you need to wait and whether or not you have the requirement to abort the wait early a queue or notifier with a timeout is also a good way of waiting"
priceless!
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 7 of 9
(3,562 Views)
priceless!
And I wasn't even using a Visa card.
Thanks.
Mark Yedinak
LabVIEW Champion
Message 8 of 9
(3,553 Views)
i lol'd
Best regards
chris
Message 9 of 9
(3,526 Views)
