What is the speed of data transmission when using Data Dashboard?
Hello, everybody, I've seen that doesn't matter if an iphone or a chinese tablet is used, the speed  of data transmission with Shared Variables and Data Dashboard is almost the same, and is low speed. Does anybody know how could I measure this speed of transmission? Thank you in advance.
Impossible is nothing
(2,513 Views)
Accepted by topic author bebin
Hello there;
The update rate of the Data Dashboard for 1.0 is fixed  1 second for webservices and 0.2 seconds for network shared variables, depending of course on how much information is streaming on the network . On the second version of Data DAshboard you can specify your update rate within a range
You can find that info in this KB
Hope this info helps.
Cheers
(2,476 Views)
Thanks a lot MarisolM, your answer is been helpful. See ya'.
(2,401 Views)
