What is the voltage range for analog out on E/M series DAQ multifunction boards?
I am trying to develop a DAQ setup by developing a labview vi which will generate analog voltage out. I have not bought a DAQ card yet, but I am planning to get a E or M series 16 bit resolution card with atleast 2 analog outs. What is the range of the voltage out on the NI-DAQ boards of E and M series? Is it -10V to +10V ? Can it be increased? If it cannot be increased, what power amplifier will you suggest if I want the voltage range to be -15 to +15? Please help.
Ujwal
(2,979 Views)
Hi Ujwal,
1. You are right. I didn't find any card that has more then +/-10V Analog Output. To choose the correct card by specs and price go to the DAQ-Adviser (http://sine.ni.com/nips/cds/view/p/lang/en/nid/10118) and follow the simple steps there.
2. About the power amplifier, it depends on the whole application u r building and the specs of the current and etc.
Hope it Helps....
The Bush-Man
(2,970 Views)
Thanks for attention The Bush-Man.
Well I understand typically the Analog out voltage range is + or - 10V. I need some help regarding choosing a power amplifier ( if I need one).
Here's a brief discription of my application:
I have a electroactive actuator. I am trying to develop a VI which generates voltage levels specified by the user through a array. What I am trying to do is to generate a voltage spike, which is faster than the speed of response of my actuator. However, I am not exactly sure whether 10V would be sufficient amplitude for my spike. So I might need say upto 15V output. Since the DAQ cards have a maximum range of 10V, I suppose I will need a amplifier. So how should I go about in selecting a correct power amplifier or signal conditioner?
Here's what I have planned right now:
Labview VI---->DAQ card----->Analog out----->Actuator
I suppose for above stated reason, I should look for a amplifier/signal conditioner between the analog out and my actuator.
Please help
(2,950 Views)
Hello Ujwal. The correct power amplifier will depend on the voltage and current you wish to achieve. Have a great day!
(2,929 Views)
