What is this Figure and... it's correct?
2 questions:
1) What is this figure (see under)? I want know what is the box (target_type) in which there is icon that I know. What is its function? How can I find it?
2)  It's correct this for expert and excellent Labview programmer (see the Figure): to pass from cluster to merge signal?
Vanny
)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(-_-)(
Sweet, Beautiful and Young Female Physicist (SBYFP)
(I speak a not very good english, so If U are Italian LabVIEW expert speak in Italian, if U speak in Eglish... please speak easy;) )
My e-mail for personal contact: vanessaricciardi@live.it_NO_SPAM_PLEASE
Message 1 of 14
(3,738 Views)
I believe that is a Conditional Disable Structure.You can find it in the Structures palette.
Message Edited by Giedrius.S on 02-10-2010 11:25 AM
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
Message 2 of 14
(3,733 Views)
Hi
1. Conditional disable structure
2. ? please elobrate
Regards
Santosh
Message 3 of 14
(3,725 Views)
2) Experts do not use the 'signal' wires, as they obfuscate the real data. Depending on the code that uses the data, use the build array function or bundle to cluster (prefere bundle by name and a type def'ed cluster).
Felix
Message 4 of 14
(3,711 Views)
Schubert explain... if the data is a Signal taked from Instrument... why "Signal" wires obfuscate the real data?
1) Can u explai in which consist the operation of blurred (like u told obfiscate)?
2) I have used cluster, but I can't connect after the cluster wires to TDSM icon. See the figure:
I desire to plot many signal to waveform chart, so Use of Cluster is very good, but I have problem after to save results.
How Must i do to solve this problem?
Vanny
Message 5 of 14
(3,711 Views)
From the Labview help :
data is the data to write to the .tdms file. This input accepts the following data types:
  • Analog waveform or a 1D array of analog waveforms
  • Digital waveform
  • Digital table
  • Dynamic data
  • 1D or 2D array of:
    • Signed or unsigned integers
    • Floating-point numbers
    • Timestamps
    • Booleans
    • Alphanumeric strings that do not contain null characters
So your datatype is not supported. Which data do you want to save. Is it the waveform chart content?
Also a tip then you start a new Labview Session always enable "show context help" in the help menu (short CTRL+h).
F. Schubert is also correct then he says not to use the "fancy" dynamic data wire. The whole Express VI concept is just some flimflam glued ontop of Labview with some cheap glue. Stay away from it and you will become a much better Labview programmer
Message Edited by Coq Rouge on 02-10-2010 12:13 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 14
(3,697 Views)
Excuse me, but how U can solve this problem?
Vanny
Message 7 of 14
(3,672 Views)
Please explain what kind of data do you want save. Can you post your full program?
Message 8 of 14
(3,670 Views)
You could insert an Cluster to Array primitive in the broken wire.
Or you could work with an array instead of the cluster, but you need to set a property (I don't remember, but might be something with 'transpose') for the chart to get it displayed the same as now.
Felix
Message 9 of 14
(3,663 Views)
The data type is Real Number.
Message Edited by vanny on 02-10-2010 07:23 AM
Vanny
Message 10 of 14
(3,645 Views)
