What is this symbol?
What is this symbol, and where do I find it on the pallette?
(2,907 Views)
Accepted by topic author jkmiller11
That is a local variable to a front panel control.  The easiest way is to right-click on the control you want to create a local variable for and go to Create->Local Variable.
GCentral
(2,893 Views)
Thank you very much. I had figured out that it was a local variable, but I had to right click and select "Change to read" from the menu.
Much appreciated!
(2,886 Views)
