What is transfer rate on PCI-6503 with Labview?
If I want to have a data transfer rate higher that 3.5 MHz with Labview General, would PCI6503 meet the requirement?
(2,804 Views)
Hi Sari
The 6503 is not a good choice! It uses unstrobed I/O. Unstrobed (static) DIO involves setting/reading digital lines by software command, that means that you don't have guaranted transfer rates (no onboard clock). This board is good for controling or monitoring switches, relays, lights and so on.
A 653x board is the right choice for higher transfer rates.
Luca
Luca
(2,804 Views)
