What is wrong with my vi?
Can anyone tell me why I keep getting the following error? "Error-200279 occurred at DAQmx Read (Analog 1D Wfm NChan NSamp).vi:2"
It runs for a few moments then shows me the preceding. I attached my vi. I am using an NI USB-6009 to read in signals from my sensors and then control my Velmex VXM (Stepper Motor Controller). However, the DAQ Assistant keeps giving me issues.
Also, I am using LabVIEW 9 if it makes a difference.
Thanks in advance!
Message 1 of 11
(4,170 Views)
You're reading too slowly, samples are filling up the data buffer and you're not taking them out fast enough, so the buffer overflows. If you're reading data then doing a lot of processing straight after, it'll increase the amount of time before you can read from the buffer again. Try optimising your algorithms, reducing loop timing, or implementing some concurrency in your VI, on top of the recommendations in the above window.
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
Message 2 of 11
(4,168 Views)
Did you try looking at the explanation?
Error -200279 occurred at an unidentified location
Possible reason(s):
Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
 It sounds like you are not reading the data from the DAQ card fast enough and the buffer is overflowing.  How fast is your loop going?  What is this LVMDriverLV8.vi?  I see it's called a lot.  If he is slow, that would explain your buffer overflow.  From what I'm seeing, I would put your DAQ code in a different loop than the LVMDriver code.  Then your DAQ can run as fast as it needs to.
Message 3 of 11
(4,160 Views)
In response to crossrulz,
I did look at the explanation. My first interpretation of the explanation was the same conclusion you drew. I'm not sure how fast my loop is going, nor do I know how to check. The "LVMDriverLV8.vi" refers to the driver prescribed by the VXM manufacturer. I have tried using two loops but the problem still arises.
Message 4 of 11
(4,134 Views)
Accepted by topic author Brandon170078
Put a millisecond timer in the loop and feed it to a shift register.  Subtract the new value from the value coming from the shift register and display it in an indicator.  Perhaps also a waveform chart as well.  That will tell you how many milliseconds each loop iteration is taking.
My guess is that it is taking longer than 100 milliseconds.  Since you are only grabbing 100 samples of data on every loop iteration (at 1000 Hz rate), you are eventually filling your DAQ buffer.
Message 5 of 11
(4,125 Views)
It takes about 200ms...
Message 6 of 11
(4,114 Views)
Your choice is then to increase your buffer to handle more than 200 samples, or find a way to decrease your loop time.
Or some combination of the above. Make sure you are reading all of the samples available when you get to the read.
Rob
Message 7 of 11
(4,111 Views)
How do I adjust the buffer?
Message 8 of 11
(4,105 Views)
I think you would be better off fixing the program. You say you created two loops but did not post that code. Your acquisition loop should not have the file write code and it should not have the VISA communication if you want to do continuous acquisition. You can change to Finite Samples or use the producer/consumer architecture.
Message 9 of 11
(4,099 Views)
Message 10 of 11
(4,081 Views)
