What is you most reused VI you came up with?
@paul_cardinale wrote:
Love the icon.
My recently most used is a sub-milisecond delay.
When i need just a tiny bit of delay when sending single characters with VISA.
Message 21 of 34
(1,276 Views)
today I'm allowed to add something... so here my wfrm renamer ..  the false case just forward the wires
Greetings from Germany
Henrik
LV since v3.1
Message 22 of 34
(1,255 Views)
@JÞB wrote:
@raphschru wrote:
@JÞB wrote:
@raphschru wrote:
 - A simple and compact error inserter:
You want to right-click that Merge Errors and select "Retain all errors" it changes the glyph so, I know you missed that additional option in 2020.
Indeed I never used that functionality, but I usually only care about the first occuring error, as subsequent errors may be a consequence of the first error.
I agree it may add useful infos, but then the default error dialog becomes unreadable and a more complex error management is required too.
Then you should:
  • Remove the merge errors
  • Slap an error case in there
  • Slap yourself silly for that
You have written add error if error in is no error
Here is my implementation of inserting an error.
Former Certified LabVIEW Developer (CLD)
Message 23 of 34
(1,245 Views)
In agreement with @JÞB, my most reused VI is "TEMPLATE Basic VI.vit" (I think I created this more than a decade ago), which I invoke every time I create a new VI (and I tend to create a lot of them, possibly "more than are necessary", but it keeps the "messy details" from obscuring what a VI is "supposed to be doing").  When invoked (from the File, New ... menu option), it creates a new VI in the standard 4-2-2-4 Connector design, with Error In and Error Out (I prefer to use these names, with Proper Case naming) wired to the lower corners, and a blank Icon (to "force" me to create something before I drop an otherwise "invisible" VI on my evolving Block Diagram.  But I also use a lot of Channel Wires ...
Bob Schor
Message 24 of 34
(1,232 Views)
Love the icon.
Why not the high-resolution polling wait?
It is the same technique you've implemented but with better precision since it leverages some windows dll
Santhosh
Soliton Technologies
Message 25 of 34
(1,213 Views)
It's a pet peeve of mine, but I always disliked how to add units to numbers on frontpanel indicators. It's either 3.14kHz (%.2pHz) or 3.14k Hz (%.2p Hz).
The standard notation is 3.14 kHz (with a space between the number and prefix), which isn't natively supported. So for frontpanel indicators needing a unit I almost always use this vi that formats it correctly.
Message 26 of 34
(1,180 Views)
Nope, Mathematically it is 3.14*1000*Cycles/Second or "3.14kHz" where "*" is implied the space breaks the math.
Message 27 of 34
(1,169 Views)
@Basjong53 wrote:
You might get a little better performance if you changed your lookup to be a map.  This would eliminate the FOR loop and it would use a binary search instead of a linear search.
GCentral
Message 28 of 34
(1,164 Views)
"%.2{Hz}p" works, but has the drawback of only working for frequency.
Message 29 of 34
(1,155 Views)
Try this
Message 30 of 34
(1,142 Views)
