What kind of variable is the "detected amplitude" output of the Extract Single Tone Information Vi?
I asked this question because I create an indicator for that output and it creates what looks like an array of a single element.
Contrary to that if I use the VI "Tone Measurements" I get just a double.
Why is that?
(2,221 Views)
Attach your VI !!!!  Then we can see how you have it configured.
That subVI is polymorphic.  If the instance handles one channel, then it outputs a scalar.  If the instance handles N channels, then it outputs an array, each element is a value calculated for each waveform.  If you only put in one waveform (a 1-D array of waveforms with only one element), you'll get a 1-D array of amplitudes with only one element.
(2,201 Views)
