What programs and add-ons do I need to install to use cRIO?
Hello?
I want to know which software products (including programs and add-ons) should be used to use cRIO.
* Products used are as follows: cRIO 9049+(NI 9381+NI 9375+NI9401+NI 9924)
So, what programs and add-ons do I need to install to use the following products?
(1,961 Views)
Hello?
(1,940 Views)
Hi Mika,
for realtime targets you need to install LabVIEW-RT-module. For full feature access you should also install LabVIEW-FPGA module (when it is included in your license). Both modules are installed additional to your LabVIEW installation.
Along with the module(s) you need to install cRIO hardware support…
(1,935 Views)
To program a cRIO, you will need LabVIEW with LabVIEW RealTime and LabVIEW FPGA.  The FPGA is optional if you want to use the Scan Engine.
(1,916 Views)
