What resistance does the Convert Thermocouple VI use for thermistor CJC?
(3,339 Views)
Presumably you are referring to when you have CJC Sensor = thermistor. In this case a subVI is used. If you are referring to the resistance for the thermistor, it's 5KOhms. You can find this out by viewing the block diagram of the "Convert Thermocouple Reading" VI and then opening the "Convert Thermistor Reading" VI. All of the information is on the front panel.
(3,325 Views)
Sorry for any confusion, as I do want to use a thermistor as cjc source on the convert thermocouple vi. I may be reading into what you are saying, but are you suggesting I need to use  the convert thermistor vi in conjuction with the previous one?
(3,319 Views)
Accepted by topic author vilh0005
No, I'm not suggesting that. I was just trying to interpret what you were saying. Smiley Wink
You indicated you were using the Convert Thermocouple VI. That VI has a "CJC Sensor" input, and it can a value of "IC Sensor" or "Thermistor". Thus, I assumed you were talking about using that VI with "CJC Sensor" = "Thermistor". In this case the VI calls the Convert Thermistor Reading VI to convert the voltage to a temperature. It uses default values for resistors, and I assumed that's what you were asking about. If you open the front panel of Convert Thermistor Reading you can see what resistance values it uses.
(3,315 Views)
Thats what I thought. I guess I wasn't viewing the vi hierarchy properly to see that is actually using convert thermister vi. Thanks!!
(3,310 Views)
