What revision of LV was used to generate project?
We have created many installers and executable files in the past years under various revisions of Labview. How can I look at a .lvproj file and determine what revision it was built under?
Message 1 of 12
(5,603 Views)
The lvproj-file is in fact an xml file. The first two tags should be something like this:
<?xml version='1.0' encoding='UTF-8'?>
<Project Type="Project" LVVersion="9008000">
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(5,594 Views)
Thanks for the quick response Norbert, but I have no idea what you're talking about. What are tags, and how do I read them?
Message 3 of 12
(5,587 Views)
Hi wb2nvy,
Project is the tag and "LVVersion" contains the info you want.
Mike
Message 4 of 12
(5,583 Views)
you have to install notepad++ and after that just right cklick to the .lvproj and open it with notepad++.
Now you can see what Norbert explained.
Message 5 of 12
(5,582 Views)
FHM -thanks. That's just what I needed to know. I did that and found this:
I don't know how to interpret LVVersion. I expected to find something like Labview 8.5 or 8.6 or 2009.
Message 6 of 12
(5,573 Views)
Hi wb2nvy,
it's nearly the same as you'll get if you use the "GetVIVersion" Method. I think it's 09008000, where
0.9.0.0 is the version
and
8000 something like a checksum.
8.5.1
would have something like
08518002 (i am not really sure if the 8002 is correct, but the first part is).
Mike
Message 7 of 12
(5,566 Views)
9008000 is LV 2009. If you open another lvproj-file from e.g. LV 8.6.1, you will see another versionnumber like 8608001.
Norbert
Norbert
Expert: Geometry
Message 8 of 12
(5,565 Views)
Thank you both. That's just what I needed to know.
Message 9 of 12
(5,550 Views)
Welcome to the world of real version numbering vs marketing version numbering.
Message 10 of 12
(5,539 Views)
