What's meaning of this USRP error and how to fix it? Thank you.
Dear friends,
My problem can run without error only for 10 sec around,  then I got this error. Anyone could advise me what's meaning of the error and how to fix it?   Thank you,
Error -1074118627 occurred at niUSRP Write Tx Data (2D CDB).vi
Possible reason(s):
A runtime or configuration error occurred.
Code: 312
Details: EnvironmentError: IOError: 0/Radio_0 user_reg_read64() failed: EnvironmentError: IOError: [0/Radio_0] sr_read64() failed: EnvironmentError: IOError: Block ctrl (CE_01_Port_40) packet parse error - EnvironmentError: IOError: Expected packet index: 17 Received index: 16
(5,309 Views)
Hi Sunson29,
What USRP are you using? What software are you using with versions (USRP, LabVIEW, etc)?
I highly recommend that you contact support at ni.com/support.
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(5,261 Views)
Hi Michael,
I am using the lastest labview on windows 10, with usrp 2943 and 2954.  Thank you.  You have any clue?
(5,251 Views)
Link the service request.
I'm about to go down the USRP rabbit hole myself.  I always appreciate the screams of those who have gone through the process before.
(5,246 Views)
Hi sunson,
There is a known issue with certain SBX daughter-boards that results in this error. The 2943 and 2954 do not use those daughterboards, so this will need to be escalated through support channels to determine a resolution. Can you contact support at ni.com/support so they can investigate this further?
For reference, here is another forum post that covers this topic.
https://forums.ni.com/t5/USRP-Software-Radio/Runtime-or-configuration-error-occurred-Error-Code-1074...
Cheers,
Michael
Michael Bilyk
(5,228 Views)
Hi Michael,
I think I made a mistake. I am using usrp 2943 and 2953 (not 2954).  Does this make any difference?  Thank you again.
(5,226 Views)
No you should still contact support@ni.com
Cheers
Michael Bilyk
(5,224 Views)
