07-04-2021 02:35 PM - edited 07-04-2021 02:39 PM
Lets say I've got a compactRIO connected to the network, and I want upper management to have the ability to view the live data. Obviously they won't have a LabVIEW license. What's the best way to go about this?
Do I make a basic website with a RESTful API? I know there's the HTTP client VI's, never used them though.
Or is there an easier way to do this? I've got the application builder module.......maybe I can just make an application designed to communicate with the cRIO via network published variables, and all they have to do is install it on their computer? (Edit: For the record, I may be thinking of using network published shared variables in an incorrect manner, haven't used those yet either)
Solved! Go to Solution.
07-04-2021 05:09 PM
I am personally not a fan of Network Published Shared Variables. They are slow and VERY insecure (anybody on the network can update them). I would make a client application that somebody can run that makes a TCP connection to the cRIO to read off the data. This would require a TCP server loop on your cRIO.
07-04-2021 07:56 PM
Ok so you’re saying make a client application using LabView? That can distributed?
07-05-2021 03:27 AM
A LabViEW built app certainly can be distributed.
