What's this component?
Hi everyone,
I'm sudying a LabVIEW application I found on the internet but there is a component used that I don't know and I don't find it, could anybody give me its name?
(see attached file), thanks
(2,698 Views)
It is called scan from string and you can find it on the strings pallette.
Joe.
"NOTHING IS EVER EASY"
(2,695 Views)
Also, turning on context help (Help -> Show Context Help) will show you a window that gives information about whatver you're pointing at. This will help you figure out those VIs that might be hard to decipher from the icon alone. Right click the VI and select 'Help' to open the LabVIEW help file and learn more about that particular VI.
(2,685 Views)
