What's wrong with unflatten from string vi?
Dear all,
I use unflatten from string VI to recover a JPEG image. Before using this VI, I should translate the bits to string. But I met a problem that when the bits have many errors, the generated string sent to this VI will cause a fatal error of LabVIEW, and the LabVIEW has to be closed. I found that the version from 2013 to 2016 of LabVIEW will cause this error, while in these versions the new IMAQ VIs are used. So would someone can tell me how to avoid this error in LabVIEW?
Appreciated for your apply!
Zefric
(2,939 Views)
Post the VI along with the sample String/JPEG data, so that can see what could have been the issue.
uday
(2,910 Views)
Hi udka,
Thanks for your reply! The VIs are atteched as followed.
The VI must read a video file, so the path is to the video.
If you change the noise power, the fatal error may happen.
Thanks!
Zefric
(2,900 Views)
Not so many people uses 7z. Kindly post it as .zip.
Mathan
(2,871 Views)
Hi Mathan,
This is the .zip format of the program.
Thanks!
(2,867 Views)
