What should be written in the "data in" of the [Telnet Write]?
When I am using the [Telnet Write] in the Labview, I write some commands into the "data in",
but there's no response.
What should be written in it?
Is any essential type of command language???
(2,629 Views)
Assuming that you've set the address and port correctly with the Telnet Open Connection function, are you appending any terminator to the string you're writing? Try putting an EOL (\r\n) character at the end. You should also first verify your connection with another telnet client. Try the example that ships with the Internet Toolkit or try the one that ships with windows.
(2,625 Views)
Thank you for your reply!
Let me try this!
(2,614 Views)
