09-22-2010 06:48 PM
I added the small event structure on the outside, only because I wanted user to confirm if all the settings which need to be done externally were set. As the while loop executed continuously without the small event structure, the program would prompt the user after every run completes. But the way I have it now, it will only prompt the user when he wants to start the test run.
I am unable to figure out how can I add a state machine for top level, as they can be considered independent events.
The original question took the back seat. Any reason why value change in "EXIT" would not execute?
Nevil
09-22-2010 06:52 PM
Attach a simplified version of your program. This cannot be debugged by looking at a picture.
09-22-2010 07:16 PM
I did figure out what was causing the EXIT event to not execute. The small evevent structure outside the main one was the culprit. I got rid of it and all worked as it should have.
Thanks for pointing it out.
