What software do I need to use NI GPIB-USB-HS in LV 7.0
Hello
I am developing a program which needs to communicate using a  NI GPIB-USB-HS . I am using LV 7.0 and would like to develop this program to run as an .exe from a memory stick.
I can install software on the target computer or on the memory stick.
The application is a laser test bed where the engineers will set up the tests at their desks and then run the test on the test computer connected to the laser.
(2,708 Views)
You will need at least NI-488.2 and possibly NI-VISA. Both are on your 7.0 drivers CD or you can click on the 'Support' link above to get the latest versions.
The hardware drivers will need to be installed on the pc where you connect the GPIB-USB-HS. You might want to consider using remote panels so that you can use a web browser to connect to the pc with the instrument. You would only need to install the LabVIEW runtime on the client pc's.
(2,695 Views)
