What software should I buy from NI to support my current exe program
I wrote an exe program connected to PLC with LabVIEW, and now I want to use it on other computers. What software do I need to buy from NI to support this program so that the cost is minimal?
Message 1 of 9
(3,544 Views)
Hi zdz,
When you created an executable then you should have the AppBuilder available.
Just create an installer from your executable - using the AppBuilder!
The installer will contain all needed software (aka runtime environment compononts) to run your executable on that other computer…
Message 2 of 9
(3,512 Views)
If I create an installer, I install it on another new computer. Because the function of DSC is used, so do I need to buy a DSC runtime module for a new computer?
Message 3 of 9
(3,501 Views)
Message 4 of 9
(3,512 Views)
Hi zdz,
you should have mentioned DSC right in the beginning!
AFAIK DSC requires deployment licenses - but better call your local NI sales rep for more detailed information!
(Please stick with "one thread per topic". No need to start more discussions in parallel threads…)
Message 5 of 9
(3,488 Views)
Thank you for your answer!
Message 6 of 9
(3,469 Views)
I want to purchase DSC Runtime system, but I don't understand the difference between "Deployment" and "Debug / Deploy" in the ordering interface? And why is the latter cheaper?
Message 7 of 9
(3,449 Views)
Hi zdz,
what's wrong with the suggestion from message #5?
What did your local NI sales rep tell you about your questions?
And why did you start one more thread instead of sticking with "one thread per topic"?
Message 8 of 9
(3,409 Views)
Sorry, I thought this was a new question, so I reposted it. I will pay attention
Message 9 of 9
(3,395 Views)
