What toolkit are the SVXMPL_Snd read waveform VI and the SVXMPL_Get Wav VI on?
I installed the Sound and Vibration toolset but when I tried to open up my VI -- it said it couldn't locate these two VIs: SVXMPL_Snd Read Waveform and SVXMPL_Get Wav VI
Do I need to install something else?  (I originally use these in a VI on Labview 6.0
(2,448 Views)
schwe,
Those VI's should be located in C:\Program Files\National Instruments\LabVIEW 7x\examples\Sound and Vibration\Utility. If they are not there,  I would try re-installing the SVT. Also, when you say that you originally used this VI in 6.0, does this mean that you are using a newer version of LabVIEW now?  Also, what version of the Sound and Vibration Toolset are you using?  If you are using a newer version of LabVIEW from when it was originally written, you may need to do a mass compile on all of your previously written VIs and Sub-VIs.  Let me know how it goes.  Thanks and have a great day!
Lon A.
(2,442 Views)
