What toolkit is Analog Tacho located
Did you find the ... \addon directory?
Message 11 of 23
(1,134 Views)
Yes I did.  It works now.  Something got screwed with the directory.  Thanks for the help
Message 12 of 23
(1,130 Views)
@Tommyboy_063 wrote:
Not sure why so many people on here are so passive aggressive.  Of course I have a license
LOL - THIS is a passive-aggressive statement.  None of the others (IMO) were.
Bill
CLD
(Mid-Level minion.)
Message 13 of 23
(1,121 Views)
Not here to argue about things my issue was solved by someone knowledgeable.  Your statement "Having a license and activating it is a key step." is very passive aggressive.
Message 14 of 23
(1,120 Views)
I think you're reading waaay too much into that.  It's just a statement of fact.
Bill
CLD
(Mid-Level minion.)
Message 15 of 23
(1,117 Views)
I purchased the toolkit in the hopes of using the analog tacho.  I installed and everything looked good until I went to select the VI and it is not in the library
Message 16 of 23
(1,119 Views)
Interesting, what versions of software do you use?
LV version & bitness?
LV license type?
SVT license type?
Check if you find the VI here - C:\Program Files\National Instruments\LabVIEW 2019\vi.lib\addons\Sound and Vibration\Order Analysis\Tach Process\OAT Analog Tacho Process (1 Tacho).vi
I use NI SVT Development (Full) licensed.
Santhosh
Soliton Technologies
Message 17 of 23
(1,122 Views)
Please do not create duplicate threads, original thread - https://forums.ni.com/t5/LabVIEW/What-toolkit-is-Analog-Tacho-located/td-p/4192729
Santhosh
Message 18 of 23
(1,118 Views)
I have the directory.  I am using the Base version.  Is this not included in the base version?
Message 19 of 23
(1,119 Views)
I have labview 2020 SP1
Message 20 of 23
(1,116 Views)
