What would be the best way to achieve what I attached below?
I am using NI-Switch. I created a simulated module NI2584. The code is working fine. I have 3 indicators that represent the switches. All I want to do is to switch ON and OFF one at a time.
Such that, Switch 1 turns ON, then OFF; Switch 2 turns ON, then OFF; Switch 3 turns ON then OFF; and so on.
(679 Views)
Hi GRCK,
What doesn't work as expected?
You seem to call the SwitchOn and SwitchOff functions in the correct order...
(676 Views)
Thanks GerdW for responding. I just don't like the duplication below. Assume, I have to add 100 channels. I don't want to keep repeating the same code over and over.
(667 Views)
Accepted by topic author GRCK5000
Hi GRCK,
The "Channel" input should be an integer value.
And your boolean indicators should be in an array of booleans: then you use the channel number to index an element of the boolean array...
(661 Views)
