What would be the veritool.zip replacement for LabVIEW 8.x. It isn't supported beyond 7
I have been told that veritool.zip isn't supported for LabVIEW 8.x.  It had worked on 7 but is no longer supported.  Any suggestions as to what to use for testing our LabVIEW code?  We have upgraded to 8.20.  Hoping someone out there can help me.
(2,767 Views)
You may be able to update VeriTool by replacing the error handling VI's.  The VI lib is rather small and worth taking a look at if you're in dire need.
TheDillo
(2,740 Views)
Thanks.  We'll give that a try!
(2,734 Views)
Please update as soon as you know something on this.  We have a similar need.
(2,696 Views)
