What would cause build info to disappear from a project?
I am working on a project that hasn't been looked at in a few months.  According to SVN, there haven't been any changes since I last committed, yet somehow all the build info is missing.
It's not a big deal because it is easily reproduced, but still yet... what could've happened?  I grabbed versions of the .lvproj file all the way back to the first committed version, but it didn't have the build info in it.  I was under the impression that the build info was saved in the .lvproj file, but it would appear that I am wrong?
Bill
CLD
(Mid-Level minion.)
(2,981 Views)
It also happen to me with LabVIEW 2015, It was a big project using "auto populating folder" if I change the project path (obviously maintaining the relative path).
Regards
Golzioge
(2,924 Views)
This is LV 2015 as well, although I am certain it went back exactly where it was when I worked on it previously.  This project only used virtual folders.
Bill
CLD
(Mid-Level minion.)
(2,918 Views)
Accepted by topic author billko
I think it's a memory issue.  MY memory issue.  The project appears never to have HAD a build spec.  At least that's what I've been told.
Bill
CLD
(Mid-Level minion.)
(2,908 Views)
