When I resize the font for the Page Labels on the tab control in LabVIEW 7, the Increment/Decrement size gets messed up. Is there a solution to this problem or is this a bug?
I have noticed in LabVIEW 7.0 and 7.1 that when the text in the page labels display is enlarged, that the arrows enlarge but the top arrow enlarges more then the small arrow but then when you decrease the text size, the arrows stay remain large. This is not a problem in 6.1 because the arrows aren't available. Is there a work around for this bug or do I have to use small text for these page label arrows to look right?
(2,712 Views)
I must admit that I've never used the page labels display and it does look like a bug. You can fix it however. Select the tab control and choose Advanced>Customize. In the control editor, select the page label control and do the same thing. You should be in the control editor for the numeric control and then you can go to edit mode and enlarge the decrement arrow to make it the same size as the increment.
(2,712 Views)
Thanks a mill! I changed the tab control and this worked out great. I didn't even think it were possible to change this. Now hopefully this will get changed before the release of LV7.2. : - )
(2,712 Views)
