When I run this VI "Waveform Time to Date Time String" in LabView 7.0 it will not pass decimals of seconds.
When I run this VI "Waveform Time to Date Time String" in LabView 7.0 it will not pass decimals of seconds. From decimals of inputline. If i disconnect the input to the subVI "Get Date/Time string vi" it will work propperly, it also doses if I reconnect it. I use LabViev 7.0.
So the problem i solved, but i dosent understund why it works in this way. Does it indicate other problems which will make my researchprogram unrelaible ?
(2,521 Views)
Hello.
I checked your vi and it fails as you state.
It runs fine if: 1 Convert number to timestamp OR
2 Wire a constant to want seconds?
In labview 7.1, no problems.
I think is a job for NI engeniers.
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,521 Views)
