When I save my images (640x470), their sizes are only 0x0. What can I do to save my images properly ?
The images that I capture have the right size but not the saved ones.
Where can this problem come from ?
(2,515 Views)
gege;
More information is needed. What type of images? Are you using the picture VIs?
You will get the best advice if you can provide a sample of your code.
Regards;
Enrique Vargas
www.vartortech.com
(2,515 Views)
The images are 8 bit images and I wan tto save them as .bmp files.
But, in fact, the images are correctly saved when I open the vi from its emplacement in a folder. I need to use this vi in another vi and the images are not saved correctly when I open it from its emplacement in this other vi.
Do you have an idea of what the problem could be ?
(2,515 Views)
