When I try to open vi, I get a message that 'Statistics.vi is not a VI".
I have been using this vi for quite some time. Is there anyway to recover a vi? I tried copying it, and opening the copy. Would hate to lose this work. Labview 6.0. I don't know what I changed to cause this problem, I can't think of anything.
(2,806 Views)
It looks like a "corrupted VI" ... something similar to A Corrupted VI in the Project Directory Crashes LabVIEW on Launch
Unfortunately, the solution seems to be just a good backup in case it's one of your own VIs.
Maybe NI guys can help you to recover it.
Good Luck
(2,806 Views)
Thanks. Luckily it was backed up.
(2,806 Views)
I've just took a look at your VI (character mode, using wordpad) and the first lines are something like this:
"Round X Y Status
1 -5.660726 15.545977 original
2 -5.660726 15.545977 original
3 -4.157382 13.668509 original
4 -4.601265 16.795809 original
5 -5.703560 16.999730 original"
If this data looks familiar to you, probably somebody mistakenly used the "Statistics.vi" name when logging information.
Anyway, it's good that you have a backup ... I've just wanted to let you know about a possible damage reason.
Hope this helps
(2,806 Views)
How embarassing. You are correct that I must have used this vi for data logging. Thank goodness for backups.
Thanks.
Liz
(2,806 Views)
