When PC System timing hits 0000hrs Loops back to start and runs again using Loop function?
Ravens Fan,
true... email doubt can do that. i forgot.
but i upload online.
http://www.4shared.com/file/pLq892VP/Lijun_AMK.html
able to download from here and extract under a same folder.
The MAIN VI for this project is : AMK_solarmonitoringsystem_vi.vi
Thanks.
regards.
Message 51 of 57
(1,118 Views)
Don't ever use the run continuous mode. Before posing any code, fix that.
"Don't ever use the run continuous mode" ???
regards.
Message 52 of 57
(1,119 Views)
That is correct, don't. It's for special debug purposes. Use an actual while loop.
Message 53 of 57
(1,116 Views)
Dennis,
i tried ways... none helps yet
perhaps i never use the correct method or not enough.
regards.
Message 54 of 57
(1,110 Views)
And never post a VI that is set to run when opened!Smiley Mad
You've got major dataflow problems. This goes back to your first post. You did not even try what I said to do in order to enfoce the sequnce. You then implemented the flat sequence structure badly.
Message 55 of 57
(1,100 Views)
i know i lousy, thats why need help badly.
Smiley Sad
Message 56 of 57
(1,093 Views)
anyone out there able to help or coach me on the problem issue i facing??
need the help badly...
Smiley Sad
david
Message 57 of 57
(1,065 Views)
