> When a program included a CIN is executed,it always indicate that some
> memory can not be read or written,please why?
> When a labview program included a CIN is executed,it indicates that
> some memory can not be read or written,then shuts down my program.My
> system is Windows 2000, please why?
Assuming that this happens predictably, place a breakpoint inside the
CIN code and step line to line. The CIN is dereferencing an invalid
pointer. A common causes is that a string or array passed into the CIN
isn't sized as expected. C code is sometimes written to take in a
buffer that is presized. The DLL or CIN node doesn't know anything
about this size, so you need to presize it using the initialize array or
using a constant.
Greg McKaskle
