When attempting to install Lego Mindtsorm 2010 Module I get error indicating need to install No Labview 32 Bit, I beleive I installed that too.
https://lumen.ni.com/nicif/us/evallegotoolkit/content.xhtml
I download files LVRTE2010std,  and LVNXTModule2010_WIN and installed them but the second did not finish.
Matt Davis
LHS
(2,644 Views)
Hi Mr Davis,
What version of LabVIEW do you have? You can find this information by opening Measurement & Automation Explorer and expanding "Software", which is located under "My System". If you do not see LabVIEW under this list, then it was not installed.
Also, what operating system are you using?
Rohama K.
(2,620 Views)
The LVRTE is the LabVIEW run-time engine and is not at all the LabVIEW development environment.
(2,617 Views)
Are you confusing this with LabVIEW for Lego MINDSTORMS? LabVIEW for Lego MINDSTORMS is a customized version of LabVIEW that is a complete development environment. It uses a customized version of LabVIEW.
The MINDSTORMS Toolkit, on the other hand, requires that you have the LabVIEW Development Environment.
(2,609 Views)
