When building my LabVIEW app, I get "Error 1 occured at Get User Input.vi".
How can I fix this error?
(2,551 Views)
Hey bmihura,
To help you fix this error it would be helpful if I had some additional information about your setup.  What version of LabVIEW are you using?  Are you getting this error when building your EXE or the installer?  Or do you get this error when you run the EXE?  Is there any other additonal text that accompanies this error?  Often times this error is associated with difficulties using dynamic VIs, are you including any VIs as dynamic?
Please repost with some more information and I will be glad to help out!
Andy F.
(2,543 Views)
Andy,
I found a way around the problem-- I built the whole system in its original directory, and that somehow fixed things.
This was LabVIEW 6.0.2, and the problem happened right after the installer was built; probably a part of the installer-building code.
(2,536 Views)
