When creating installer files, there is an error:the system cannot find the customResource2052.dll file, what's the problem?
I am using labview2009, when I create a installer, there is an error report as blow:
 Error: Windows SDK function returned an error. (Error code -12)
Error accessing a resource module "E:\工作资料\项目资料\绿盾\builds\Untitled Project 1\...\Volume\supportfiles\customResource2052.dll".
The system cannot find the file specified.
*** Error Details:
Error in MDF API function: _MDFBuildDist_Build
Error in MetaToolbox::UpdateResourceString.
         strId: 3; New String:     ; LangId: 2052
Windows function LoadLibraryEx returned an error. Error code: 2
*** End Error Report
(2,770 Views)
Hi super008,
The error can be due to some improper installation of a driver or any NI SW that the Installer requires.
Have you recently installed or Uninstalled any NI Software ?
Also -
You can see in the KB below -
That it could also happen due to some incompatibility with the .NET framework or adding exception in the AntiVirus.
SDK Error Code -12 When Building a LabVIEW Installer or Installing LabVIEW
http://digital.ni.com/public.nsf/allkb/AFC375154EFBD6AE8625760B005FB723?OpenDocument
One more question :
Do you have any idea what is this resource :
E:\工作资料\项目资料\绿盾\builds\Untitled Project 1\...\Volume\supportfiles\customResource2052.dll    ????
is "Untitled Project 1" your project ?
(2,758 Views)
Thanks for your information. As you said, after I closed the anti-viruse software of my computer, the error disappeared.
(2,741 Views)
