When do I need to redeploy a Shared Variable?
I am using 2 network shared variables to share data between cfp-2220s.  The shared variables are both clusters of several deifferent data types.  Do I need to redeploy the shared variable everytime I add or remove a variable from one of these clusters?
(2,746 Views)
Hello DrewCommPower,
Yes you will have to reconnect the custom control that defines the cluster and redeploy the shared variable.
Wear
Product Support Engineer
(2,713 Views)
