When fitting an exponential curve, how can you
get the fitting to implement a Y offset to the
fitted data? The offset changes from sample to sample, so it would need to calculate that also.
(2,899 Views)
Look at the nonlinear lev-mar fit. This curve fit routine is supplied with an example equation that it fits to, but you can "save as" and create your own lev-mar curve fit to any equation that you plug in. I used it successfully to curve fit to an exponential+sinwave type equation.
Stu
(2,899 Views)
I'm with Stu--go with the Nonlinear Lev-Mar Fit. The helpful aspect for you is that the default fit equation hardwired into its "Target Fnc & Deriv Nonlin" subVI is actually the very function you're trying to fit:
y = a0*exp(a1*x) + a2
Here, a2 is the offset you're asking about. If you simply wire your X and Y value arrays into the Lev-Mar inputs and provide an Initial Guess Coefficients input of [1,1,0], you'll probably get a decent result for data that crosses close to zero.
John Lum
National instruments
(2,899 Views)
