When i run my program, i get the following Error:
" Error 7 occoured at Open File+.vi:Open File.
Possible reasons:
Labview: File not Found .
or
NI-488: Non-existent board.
Please Help?
(2,929 Views)
I suppose you are trying to open a file, but LabVIEW can't find it. One reason can be that file is not there, another one is an error in the file path you enter, check it.
Hope this helps
(2,929 Views)
In my experience it usually happens when one of my sub VIs is trying to open
a file and can't find it. (We don't use the NI-488 boards, so for us, the
error is due to a problem opening a file. If you are using GPIB boards, the
problem might be due to a missing GPIB board.)
Hope this helps.
Jim
matrix wrote in message
news:506500000008000000BA1D0000-986697009000@quiq.com...
> Possible reasons:
> or
> Please Help?
(2,929 Views)
