Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
When if statement is used in LabVIEW, can I add more than one statement.
Baho
Member
01-20-2004
01:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Ex: If (t<=2) (Amp=2*t Len=t*0.1); Is this correct? Or do I have to use If (t<=2) (Amp=2*t);
0
Kudos
Message
1
of 2
(2,468 Views)
Reply
Re: When if statement is used in LabVIEW, can I add more than one statement.
Meghna Vora
Member
01-20-2004
02:25 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
When if statement is used in LabVIEW, You can add more than one statement. For that, use following syntax
If(t<=2) {Amp=2*t;Len=t*0.1}
Thus, sentences have to be in closed parenthesis & separated by semicolons.
1
Kudo
Message
2
of 2
(2,468 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
