When installing an executable, how do I prevent the installer from uninstalling a previously built executable?
I'm trying to install a newly built executable on a machine that has a previous version of the same application. I want to be able to run either version on the same machine. The problem is, when I run the installer (also newly built) it uninstalls the previous version. How do I prevent this from happening? I'm using LV8.5 Professional, Windows XP.
pmac
(3,887 Views)
Can you change the name of the application executable? I don't think it will delete the old one if it has a different name.
PaulG.
Retired
(3,882 Views)
I've tried everything I can think of - I changed the name and location of the application executable, the name of the installer, the product version number, and I saved the project with a new name. Each time I've changed something, I rebuild the executable and the installer and then run the installer, and each time it uninstalls the previous version.
I modified the existing application to make an engineering version that only one or two people will use temporarily. I still need to maintain the original on the same machine for normal daily operations. It shouldn't be this difficult, should it?
Thanks for your suggestion.
pmac
(3,874 Views)
pmac
(3,874 Views)
In your Project Explorer>>Build Specifications, create a second build configuration for your new executable, and a second installer.  Have different names for these, and your executable files than your original ones.  Let me know how it goes.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(3,860 Views)
If you are using version 8 or newer, the easiest thing to do is to create a new project.. Once you create a new project, for whatever reason, it looses connection to the older version.
(3,853 Views)
That works!
Thanks SG.
(3,849 Views)
