When multipling two different "Triangle Waveform.vi"s
When I multiply two "Triangle waveform.vi" with different amplitudes and frequencies,
the result is not linear but non-linear such as attached picture.
Is it a bug?
or
Am I making a mathematical mistake?
(1,708 Views)
Accepted by topic author dream4me
Looks fine to me, why would you think it is a mistake or bug? try doing the same on a piece of paper.
Santhosh
Soliton Technologies
(1,679 Views)
[Edit: oops, queued it up, walked away, and finished later.  Kinda redundant now.  Oh well, here it is anyway...]
Well....
y1 = a*x
y2 = b*x
so y1*y2 = a*b*(x^2)
...which explains the parabola shapes in your graph.  A linear shape would result from *adding* the two waveforms.
-Kevin P
(1,669 Views)
As you said, I wrote it down on a piece of paper and then I had known the reason about that.
Thanks a lot.
(1,657 Views)
Oops, I didn't see that this had already results in responses and a "solution" ...
You aren't making a mathematical "mistake", but do have a mathematical "misunderstanding".  Suppose I have a function f(x) = x, and I multiply this function by itself and call the result g(x).
g(x) = f(x) * f(x) = x * x = x².
You are multiplying two linear functions and are seeing piece-wise quadratic results, what you should have expected.
Bob Schor
(1,613 Views)
