When opening PT Assembler, Windows tries & fails to open NI Run-Time engine
I am using PT Assembler, a front-end for the Panorama Tools software bundle, to stitch microscope images taken by LabVIEW using the QCam Suite.  Whenever I attempt to open PT Assembler, Windows informs me that it needs to configure the NI LabVIEW Run-Time Engine 7.1.1, which it cannot as it is not installed.  After cancelling the configuration 4-5 times, my program opens and runs without errors.
PT Assembler has absolutely nothing to do with with NI or Labview as far as I can determine, so why does Windows try to open it with the run-time engine?   I attempted to install the 7.1.1 engine from ni.com but was informed that it was unavailable.  Is there any way I can keep Windows from attempting to use the engine?  I could install a later version of the engine and hope it works, but I am a bit leery about how it might affect my program.
(2,733 Views)
Hi rhazelton,
If this program hasn't been created in LabVIEW, then I'm not sure why it would be doing this..  However, you should be able to download the 7.1.1 run-time here.  Give it a try and see what happens!
Brian A.
(2,714 Views)
Thanks for your suggestion!
I tried to install 7.1.1, but it failed because a later version was already installed (and if so why would windows be trying to open an earlier version?  So confused...) but I installed 8.2.1 instead, which did work.  Thank you!
(2,705 Views)
