When program is aborted it automatically saves the data into log file
I am sorry I don't understand it.
Message 11 of 14
(499 Views)
What is "it"?
Message 12 of 14
(494 Views)
your message.
and also, how to undo if you mistakenly press ACCEPT as SOLUTION.
Thank you.
Message 13 of 14
(485 Views)
your message.
It is basic math and you should be able to debug by probing the wires. Your remainder will be zero for 100 iterations, i.e. until 1 second has elapsed. then again for 100 iterations at 1 minute. (See attached simple demo)
As I said since you have a constant loop time you can base your save frequency in the iteration terminal. No need for the express VI.
Message 14 of 14
(473 Views)
