When running labview's test executive I recieve runtime error: Call to step "PRE-RUN" failed. Could someone explain this error?
I have a set of vi's that work when run under labview. However, when calling these vi's from labview's test executive I recieve runtime error: Call to step "PRE-RUN" failed. in Assign Connector Pane.vi->Call Test.vi->Execute Pre-Run.vi->Test Executive. Could someone explain this error to me? (or ideally tell me how to fix it?) Thanks.
(2,604 Views)
There are any number of possible causes to this problem. Which version of Test Executive are you using? Have you upgraded your Test Executive recently? The latest version is 5.1.1. If you have changed anything about Test Executive on your computer recently, I recommend you perform a mass compile of all your VI libraries, as having different versions of the VIs on your system could often result in the "Call to Step XYZ Failed" errors. Also, are you using any DAQ or Analysis VIs in your steps? We have seen problems where the use of DAQ or Analysis VIs in the sequence can cause intermittent "Call to Step...Failed" errors. There are some KnowledgeBase entries on our website that discuss this problem. Are you using the Test Executive in the VI environment, or
as an executable? Again, there are some problems with using Test Executive as an executable that result in these errors, and there are also KnowledgeBase entries that discuss these problems.
If you have a pared-down application that demonstrates the problem, feel free to send me your VIs and your .seq file and I will try to reproduce the problem.
Alternatively, I would suggest you visit www.ni.com/teststand to learn about TestStand, our state-of-the-art Test Sequencing software that completely outperforms Test Executive. It is very easy to use and much more powerful, and we have a top-notch support team available dedicated exclusively to supporting TestStand. As you are probably aware, we are no longer developing Test Executive, and instead are concentrating our efforts on making TestStand the penultimate solution for all our customers' test sequencing needs.
I appreciate your patience on this issue. Please let me know if I can offer further assistance.
Have a pleasant weeken
d.
Sincerely,
Darren Nattinger
(2,604 Views)
