When saving data to a file how do you save them in intervals?
I have an SCXI 1102 and I am reading thermocouples. I am saving them to a file. How do I set up an data collection interval for the file and keep it separate from the data collection interval for the real time data on the front panel.
(2,867 Views)
If you don't want to save all samples to file, in your DAQ-application build a timed loop. If the time-interval is reached, a boolean gets true and the latest samples are converted to string and written (added to) a file. It's just a little extra code.
(2,867 Views)
PdB
here is what I have I cannot seem to get a timed loop to work. Could you look at this and tell me whats wrong. Thanks for your help.
(2,867 Views)
The simplest method to achieve timed loop can be found at:
http://zone.ni.com/devzone/conceptd.nsf/webmain/E83351E12CD2D50886256B66006E4D15?opendocument
However, you can achieve your objective without even using timed-loop unless this is critical. I'll post a vi to show you another way to get it done.
I want to suggest you make the following changes to your vi: move write/lose file vi outside the loop and your data sampling vi should be inside the loop (again, this can be done in several ways).
(2,867 Views)
I modified your vi to let you do data collection at any interval you want. The attached two files include the changes, Test vi is the one I used to test the vi functionality. The other method that I mentioned in earlier post is for continuous data acquisition, I'm not sure that will be of any help. Note some other changes made to your original vi.
(2,867 Views)
