When should one use "Quit LabVIEW"?
Several points to remember:
- A LabVIEW built application is terminated as soon as the last front panel is closed, even if the diagram has not terminated executing! Closed means closed, if it is hidden that does not count as closed.
- Quit LabVIEW aborts everything in the current application context but not necessarily everything, although you would have to go to some length to create multiple application contexts in an executable.
- When the diagram stops executing, its front panel is not automatically closed. You have to close it explicitly somehow.
- One option is to close the front panel through a method node. The other is to call Quit LabVIEW which will abort all VIs in the current application context and then close their front panel.
- But making sure to close all front panels explicitly (preferably as last step of the diagram of the last VI  to avoid the first point above kicking in) is enough to terminate an executable, as the executable process is automatically terminated by the LabVIEW runtime system as soon as there are no active LabVIEW child windows present anymore (there always is a hidden root window present but that is simply dispatching the OS events to the LabVIEW runtime root loop and the one entity monitoring if the executable has still any window open).
Rolf Kalbermatter  My Blog
Message 11 of 21
(3,567 Views)
I will typically use a Quit LabVIEW in a Case structure with App Kind = Run Time Engine after discarding a Panel Close? Filter event and running any cleanup.
This allows the normal experience for the user to end the application with the Windows X.  Yet does not close the IDE during development.
I suppose I could invoke This VI FP Close instead inside the case structure.  I would avoid that unless I fully documented that anyone inheriting the code maintainance MUST follow the rules Rolf stated or risk unexpected behavior of the built app under some circumstances.
I have found no use for Quit LabVIEW outside that specific case.
Message 12 of 21
(3,514 Views)
That's actually a pretty sneaky trick.
Bill
CLD
(Mid-Level minion.)
Message 13 of 21
(3,501 Views)
I thought everybody knew that one.
It's dangerous though. If a dynamic process is still busy doing something, like saving configuration, it will be stopped doing that.
Message 14 of 21
(3,483 Views)
Instead of using a Case Structure, use a Conditional Diagram Disable Structure.  It will eliminate the need for the property node and make life a little easier for the compiler.
Message 15 of 21
(3,477 Views)
Conditional disable structures didn't always exist....;)
Message 16 of 21
(3,462 Views)
As a rule, all parallel Message handling loops are guaranteed stopped by dataflow prior to calling app kind.  An ACBR fire n forget process would need to have some safety exit and collect status.
Regardless,  it only gets dangerous when you learn enough to expect everyone else is smarter than you!
And, we LabVIEW ninja don't call call them "sneaky tricks!"
Message 17 of 21
(3,458 Views)
They existed at least back to 8.2 (farthest I can check).  Though, it looks like the "Runtime_Engine" was not a symbol back then.  I've been using this trick for at least a decade.
Message 18 of 21
(3,454 Views)
Actually that is not quite correct. But some people know enough to be dangerous, but not quite enough to realize that they are dangerous. 😀
Message 19 of 21
(3,452 Views)
Hence, my preference for Quit LabVIEW! 😀
It keeps me from looking like I didn't expect something like that from the next developer.
Message 20 of 21
(3,448 Views)
