When starting vision assistant8.6"requier a minimum display of1024*768
(3,421 Views)
Your issue has nothing to do with converting between different LabVIEW versions.
Post in the LabVIEW forum.
(3,413 Views)
OK. But how to deal with this problem? Could you help me? And I found the same problem when starting the vision assistant 2009.
(3,407 Views)
I can't because I don't work with Vision.  But if you posted your message in the proper forum, more people who do know vision will see it and you might actually get some help.
(3,400 Views)
